council for production of a particular
  • Thread starter Thread starter corsaro33
corsaro33
Good morning,
I have a question to ask for the production of the annexed detail.
"the material of the piece is in c10"
currently this particular is produced manually,
as the number is becoming unsustainable, (10000 year)
we ask and ask you what alternative it is possible, (printed, bent, cheated etc.)
the only dimensional bond is a certain precision of the picture in the part
of the four bevels (10x10 +0.00 -0.1)
thanks in advance for the answers.
But now how is it done? I'd take some strings to measure, cut it off, and then I'd move to the fold in shape.
Hello, mtbnicola,
is done just as you say,
in addition a passage to harassment for final bevels
good morning to all, the automatic alternative to me would be to build a cutting bench and that also make as a bending machine. each cycle will produce 4 pieces at a time. What do you say? ? ?
Hello Alex,
I don't know what you mean by "cut bench"
Maybe because I've never seen one...
Sorry, you're perfectly right. practically would be a table of size more or less 1m x 1m with engines equipped with blades and pneumatic cylinders to perform bending.
I would need 2 odds that are not in the image of the product. the quota in x and the tilted cut at the end. I'll give you a box to show you my guess.
10x10 mm:rolleyes:
Maybe na normal bending machine solves your prob or a v mold
matrix and punch where in the specific angle must be considered the "return of the material"
then define the lengths with saw cut
Thank you very much
10x10 mm:rolleyes:
Thank you very much
hi shiren,
our problem, is to make the construction of this particular (simple)
as automatic as possible,
the fold of the piece we make it to the bending machine and putting 20-30 pieces at a time,
the problem is the two cuts to the seghetto one to 90° and the other to 38°
more the bevelling sutto the harassment.
Cut out developments with angle and then make a fold to v mold even though quite often 10mm
to cut the pieces you could make a mask and cut it with the disk maybe mounted on a tacchella and the bevel always with a tool that allows to rotate 90° in 90° under a grinding wheel
Guys in my opinion must be laser cut! If you need to send the design and order that I will take care of!
..we hope that after 5 months the Corsican friend has solved:biggrin:
Marco:smile:
