count parts in a drawing
  • Thread starter Thread starter blubossa
blubossa
is it possible to make the drawing of a part and inside the cartiglio have in automatic the total number of pieces previewed for a certain set?
bb
Yes, just add to the drawing the model of the axieme and insert a table for separate base connected.
add the model together with the drawing of the component you intend to obtain the distinct.
insert a table containing the correct parameters to obtain its distinct.
apply a filter to get the amount of the only or component of your interest.
therefore it is necessary to insert the axieme:frown:
and by code alone, or various filters is not possible?? in the drw I need not see the axieme but only the listed part.
bb
I thought about it....
You think there might be some other solution to go?
I thought that if I can get the numbers in the info table, it could probably be possible to point (only by code to write for example in the report editor) to a set to know the number of parts present.
What do you say?
bb
hi maxopus,
I'm trying to follow your advice but I can't, can you help me with an example?
bb
