count selected objects by distinguishing them by layer
  • Thread starter Thread starter Denis-Ferrazzo
Denis-Ferrazzo
I have a question to ask you: is there any utility or lisp that accounts for the objects of a certain layer on, distinguishing in the reporting phase the number per layer and the type? !
example:
I keep 3 types of layers on and off the rest of the drawing, select the objects of these 3 layers, click list and report tells me:
n° 125 layers a
No. 735 layers b
n° 256 layer c
There is a procedure that allows me to do this with the blocks...but in my case I can not use blocks. .
Thank you in advance!
Great. lol is the command for me! a small thing...Is the report of the number of all the layers present in the design...is there a possibility to select only the 3 or 4 layers that I need and count only those? ! ?
see if it can serve this variant of the lisp, to be launched for each desired layer.
p.s. two blocks on the same layer are counted as two objects on "quel layer", regardless of where the objects are placed.
