country problem
  • Thread starter Thread starter cikho
cikho
I am probably the one who is particularly gnubbous (inexperienced :d ), but I have a problem not recently in putting into the table some pieces that I am making. .
In particular, I have a problem with the sampling of pieces with a cylindrical profile. .
when I make the table the contours of the drawing are very precise, but the sampling seems to follow approximate profiles.. as if it were set on low quality and approximated the curves to polygons. .
the most annoying thing is that, for example in a set of two concentric "tubes", this approximation is not even "allined" so the sides of the hypothetical cutting range do not match and the fields overlap one with the other.. (example in attached image)
How the hell do I correctly set the samples? :mad:
In fact, this sort of approximation also exists in model 3d, and it makes me quite mad:/
try setting the config.pro option (tools > options) edge_display_quality su high. probably in your case is set to low.
ciao.
the situation seems to improve, but still remains unpredictable.. boh.
was set to normal, now I put it on very high
