couple parts in subaxis
  • Thread starter Thread starter sofa80
sofa80
Hello everyone
I just started to create axioms formed by various subaxis in top dowun projection(in attachment the example file)
the problem found is that I initially failed to mate the part g01-fianco slept. del sottoassieme rubber ball with the part of the under sp. mobile. I managed to solve by making the subaxis rubber roller shutter flexibly, but at this point because if I open the window of the subaxis rubber roller shutter the part is not bound .?
Is that normal? Can you trouble me? or do I have to make it fixed somehow?
I hope I've been clear
You're working badly.
-subassie me with one part
-subassiemi with two parts both fixed
-subassiemi with too many fixed parts and other untied
-original parts without meaning
-Spring sp. mobile you could do as a multibody part
- in rubber strap you made a body mirror with opposite hand of a symmetric piece, it is a useless operation since the two details are equal
and this at a quick glance
However what happens to you because you are mating in a higher-level set. the couplings do not propagate to the subaxis.
It is equally right that you have to make the subaxieme flexible to bind an untied part within this subaxieme, which you have made fixed you do not know why, in order to make it binding to the upper axieme.
I think you miss the basics of modeling and software operation. I recommend you a course or do yours
-subassie me with one part the project is not finished-subassiemi with two parts both fixed I have always seen, read that the parts must be lived at least that does not need movement-subassiemi with too many fixed parts and other untied I repeat I always knew that the parts should be fixed-original parts without meaning probably due to the fact that the parts are all created in the main set (top dowun)-Spring sp. mobile you could do as a multibody partI prefer to create the subaxieme because it is easier for me to put into the table with relative distinction to go into production - in rubber strap you made a body mirror with opposite hand of a symmetric piece, it is a useless operation since the two details are equal I made the mirror because when I have to parameterize, then create a different size of sofa, increase the back is both on the right and left sideIt is equally right that you have to make the subaxieme flexible to bind an untied part within this subaxieme, which you have made fixed you do not know why, in order to make it binding to the upper axieme. if I don't make the very fixed (created in the environment together) the parts I go to create are always mobile even if the sketches are bound
I have always seen, read that the parts must be fixed at least that does not need movement
only the first part must be fixed, the others must be coupled. how do you position the parts and then make them fixed?
You also do it with the multibody part and the cut-off. but rightly they are internal choices.
I've figured out how you shaped... in the light of that subaxieme or make it as flexible as you did or do a distance mating that you will parameterize with a share of the first level axieme.
only the first part must be fixed, the others must be coupled. how do you position the parts and then make them fixed?I create the part directly in the axis, insert component - new part , click in the space and the part created and fixed, of course the sketch is made where the part has to take shape, perhaps on parts that refer to other assembliesI've figured out how you shaped... in the light of that subaxieme or make it as flexible as you did or do a distance mating that you will parameterize with a share of the first level axieme. I understand what you say, but if you want to make the subaxieme flexible in the main unit, g01-fianco slept I don't know if it's right or not, if it could make me trouble with work.
please, share with the appropriate system: write [QUOTE*]...[/QUOTE*] without asterisks and instead of the dots you fill the text. to not write every time that piece of code expand the arrow that you find next to the emoticon face.
I create the part directly in the axis, insert component - new part, click in the space and the part created and fixed, of course the sketch is made where the part has to take shape, perhaps on parts that refer to other assemblies
I came after that. I didn't understand why if you did top-down modeling there were both fixed and coupled parts.
I understand what you say, but if I wanted to make the subaxieme flexible in the main group, the g01-fly part is not fixed, so I don't have any problems.
as I have already written you have two possibilities according to how you want to proceed:
you want the flexible axieme? then it's okay as you did, but the coupling is done at a higher level and you can't find it in that containing the part
b do you want the non-flexible axieme or in any case the bound part in its subaxieme? Then it's not as good as you did. you have to create some coincidence couplings between the rear faces and the upper faces and a distance coupling by connecting it to a quota, equation or other of the main axieme; Alternatively inside the subaxieme you can create a specchatura plan using the geometry of the main axieme and then mirror the part
I don't know if it's right or not, if it could cause me problems with the work.
I would not have managed the sub-assistances in that way that is with parts not united among them because it already means knowing from the beginning how the final work will be that there will be no changes in course of work. sub-axioms should reflect the assembly and management of the contract. we take your case: you have the central frame that is pre-assembled and managed as if it were a unique element, you have the back also pre-assembled and managed as a single part, you have the two pillows managed as a separate voice, then you have two side parts that cannot be preassembled together will be part of a unique management voice. so even if you in that subaxieme had to put dowels, screws, other elements would have a g01-fianco slept left and a g01-fianco slept Right. I hope that this draw is clear what I mean.
if you do not want to run into problems you have to prepare upstream, before starting the job, a subassiemi management scheme and do not move forward tightly to then put pieces to the right and missing.
to answer your question if you find yourself with problems in the continuation, realize that you have wrapped yourself up for a basic couple. but the project you know only how it will evolve and how you will manage it
