peppemrc
hi guys, I have a doubt about the torque represented in the various tables.
I have to fix a plate with screws and bolts, but the chockfast located under the plate must undergo a compression < 35kg/cm2.
I have to use m20 screws. but if I apply the cone values from table to 0.2 of attrite coeff., I quite exceed the compression of the chockfast. I also tried to use pairs with lower friction coeff. and to vary the grade of material to 6.8 but the value of compression grows.
My question is:
Can I reduce the value of the tightening couple?
example:
screws m20 8.8 to 0.20 friction, torque 471nm.
Can I use with same screw and friction a pair of 285nm? How do I know if this value creates vines workouts?
My question is:
example:
