reggio
Hi, I recently found out that my external turning machine could load cnc iso program on his car,
it could be the opportunity to speed up the times and make a little thought at the upgrade sxw (if I didn't understand bad the ns version 2016 did not have it, but from the 2018 version they integrated the possibility to export the models in cnc.
I ask the courtesy to those who have swx2018 or superior to turn "tree test-40257-c1_034_00_410.zip" into cnc iso for lathe doosan puma 2600y bii (or other lathe - to what I understood he will use only the coordinates, fixing the tool type and initial data hand program) to make a first test with the lather.
Thank you in advance
