cousin use di revit
  • Thread starter Thread starter pillodudo
pillodudo
I started using revit, I'm quite experienced in autocad and I easily use solid modeling.
to better understand the program I imported autocad files and recalcated the plants of the different floors
1) at level 0 I designed both the ground floor and the first, how do I move it to level 1 and overlap it, exactly, on the ground floor?
2) how to create new levels (second floor, etc.)?
3)I created a set that by default is 3 meters high, in sight 3d allows me to lower it through a dart, but it doesn't give me numerical indications and then iron randomly, how do I make the vertical quotator appear to understand how much to lower it?
4)How can I change a parapet, I want it to horizontal bars, from a duplicate of the railing? where do you enter the solid modeling of a component?
5) in the local label can you insert the automatic calculation of the aeroilluminating ratio?
I hope I have not put too many questions probably also banal, but in the beginning they create remarkable rocks to the continuation.
thanks in advance
Welcome to the forum.
I always recommend to everyone, as the first to open the sw to perform the exercise contained in the installation cd, which allows to have a first and concrete approach to the use of the software.
on the merit of your questions, I inform you that these topics are already dealt with in the discussions on the forum.
a "search in the forum" button in the main forum of revit, with key words insertion, to track discussions.
some are here:http://www.cad3d.it/forum1/showthread.php?t=6653&highlight=murihttp://www.cad3d.it/forum1/showthread.php?t=17160&highlight=iniziohttp://www.cad3d.it/forum1/showthread.php?t=12105&highlight=murihttp://www.cad3d.it/forum1/showthread.php?t=9650&highlight=rai+rapportihttp://www.cad3d.it/forum1/showthread.php?t=9451&highlight=muriin the discussions highlighted, at the beginning of the forum, are marked links to the site autodesk revit, for manuals specific to the use of the sw
... good research... and good reading... .
Thank you for the courtesy, but through the links I did not find an answer.
There is a continuous referral to other links and I know, told without controversy, that beyond revit, I have to study how to move through the forum.
certainly not more thirty years, but forty-year-old advanced does not make me quickly grasp the links, but I am adding complications to complications.
at least understand if there is a fast system to find information. . .
