crash autocad lt 2011
  • Thread starter Thread starter vannicad
vannicad
I'm new to the forum, and I don't know it at all because I use my partner. I just need to install it. I explain the situation:
1. installed windows xp 32 bit Italian fresh
2. installed office xp Italian
3. installed symantec endpoint
4. installed autocad lt 2011 Italian
when I open any dwg file the autocad crashes and there is nothing to do. It's practically unusable.
Because I'm just a neophyte, is there anyone who has a suggestion to give me?
vanity
try: try to disable various antivirus and spyware. . .
if you create new files the problem looks the same?
I had already tried to stop the antivirus --> same problem!! !
I also tried to create a small file from scratch. close autocad and reopen it--> opens it without problems.
It's like you messed up opening a file with a version that's definitely previous! ! ! !
vanni.
for the moment I found only this knowledge
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteid=123112&id=7236884&linkid=9240817may also be a framework problem, but the fact that it normally opens files created ex novo seems strange to me. . .
Have you tried with several files of previous versions?
heavy and light? do they contain strange elements? all created with other versions of autocad or other applications?
I will try to apply this.
vanni.
