crash di revit
  • Thread starter Thread starter render54
render54
between one thing and the other I installed revit 2012 only lately when I got the usb key with the 2012 version in Italian.
in these days doing a job I used "manage" > "unused elimination"
revit jumps and goes out, same thing happens on the version installed on the pc at home.
strangely opening a new design the same command does not give problems
at this point I tried to open other drawings of 2011 and this error does not give it
exists a way to verify the project, if there is something that creates this problem?
since it doesn't even give me the data entry window problem to autodesk
Fortunately, the open project doesn't give any problems by working on it.
but irritates the fact that you can't clean it up
The window that comes out gives me these details problem,
if it was a problem of win7 would do it with all revit projects
event name problem: appcrash
application name: revit.exe
version application: 2012.0.2011.309
timestamp application: 4d785e92
form name with errors: usp10.dll
module version with errors: 1.626.7601.17514
timestamp module with errors: 4ce7c9f5
Exception code: c0005
offset exception: 00000005064d
version so: 6.1.7601.2.1.0.256.48
id local settings: 1040
additional information 1: 498a
further information: 498a4539eb764424b866f748c0f2e199
more information 3: e910
further information 4: e910cca723b26abf5ed608b3206f246d
if someone knows something about it
ps.
I opened the project with revit structure
from the same problem
did you also install service packs and hotfixes?
if I don't remember badly, the initial version 2012, at first gave some problem with the materials (of the files made with previous versions), then solved ...
It seems to me that there is also some discussion about it...
Mah! is only with the files of this project, from a file, I duplicated it to make 2 more solutions
that then I insert with colleague revit on the base file (they are done for the office part of a shed) the files of this job when I give the command, revit comes out, other old or new files that are working.
I'll keep my plans clean.
It is that I did the 3d also of the interior and I have inserted a lot of material that now I don't need anymore.
thanks to the answer
