crash errors on 2d\3d boards
  • Thread starter Thread starter Bosca74
Bosca74
a hello to everyone from a new writing.
I ask if someone has ever had crash issues with the program, especially in using 3d boards. While working there are errors, apparently, without particular reasons of the type:
"an internal error occurred. the performance of thinkdesign will be finished”
- “execption unknown software error occurred (0xc015000f) in application to position 0x7c9579cf”
- the instruction to “0x16049d4a” refers to the memory to “0x02a92da0”. memory could not be “read”
errors completely different from each other but leading to the only common result of crashing the program.
the video card was also replaced with the picture fx 1800 768 mb, but without result.
PC data are as follows:
hp xw4300 workstation, repentum ® 4cpu, 3.40 ghz, 2.00 gb ram
a greeting
so many years ago, when I used td, it was daily bread, and assistance could never solve the problem.
I don't think it's a hardware problem anyway, at least as far as I'm concerned other cads worked well on the same computer.
Yes, but momentarily they can't solve the problem,the strange thing that this kind of errors come out only on this pc.
hello open the help file and type grafich card searches the table with the indications for the various graphics cards and system with what they explain for your to me to run.
I reformatted the pc, and installed the following driver for the video card:
182.65_quadro_winxp2k_international_whql.
“Touching iron”, momentarily seems that everything works, in the case of errors I will alert you!
nothing... working on the usual tool I appeared the usual mistake.. .
“an internal error occurred. the performance of thinkdesign will be finished”
I also tried the suggestion of tecmec, which somehow memorized the error in the design file (an internal crash), which consequently resumed it to every modification?
Try to verify that the ram isn't ruined, I mean, if you have two cards, you take one at a time and see what happens.
However if the problem always arises with the same file, most likely it is corrupt file. I remember once there was a "compact" function of the file, is there still?
hi, what do you mean by "compacting" of the file?
Try to look in the menus but I'll open it up almost ten years ago, but enjoy this function no longer exists. Anyway, if it's a single table, I think you're gonna do it again first, sometimes it happened to me with solid edge at the time of the v12, a 20-mb joint draft evaporated...
..to extreme evils...extreme remedies.. we try to install think on another pc, since the problem only happens on this! !
So... under plots. and then I would try to make also tools->modelling-> regenerates everything.
.. also try to copy and paste the template on an empty file... I've never tried, but maybe he loses crap.
good work!... here you are waiting for 2010... and we are in 2011...
