crash from drawing environment (idw)
  • Thread starter Thread starter Quoque69
Quoque69
save to everyone for a while I happen that while I'm listing a piece (in idw environment) inventor suddenly closes
use inventor 2017. I also happened that while I was out of inventor's office, it ended.
Does it happen to others?
Did you solve the problem?
is a system that uses vaults with network licenses
thanks to all in advance
Bye!
It happened to me that it was closed by doing very trivial operations (for example, passing from window to window or setting a view on the table, etc.), but as ignorant in the matter I blamed the pc more than the inventor, I thought maybe it had not enough memory.
The difference with your case though is that it happened to you in similar situations, several times quotating, I could not tell you if there is a more frequent condition among those in which it closed to me, I think not. I'm sorry for the bad Italian! )
I must also say that we have not installed the various service packs and updates. cmq doesn't happen to me often, just occasionally.
bad, no updates and sp. the only thing that works well by inventor is crashes.
if you are then put as you describe in the other discussion, each with his rel., only the great hand of buddah protected you.
Yeah, you're right.
you will ask why we do not install sp and update since they are free... But I suspect you don't even want to know the answer.. .
because we cannot use the autodesk account! :-( :-( :-( )
with the mania to keep everything ultrasecret and with the fact of using different versions and occasionally exchange the licenses and various amenities there was some problem with the accounts, so "to simplify" all the boss decided to accent everything under a single account (in which he managed to wrong also his baptism name, I don't know if you understand the level..) of which he lost the password, if the end did not delay
I know it's hard to believe, but this is always the same that measures threads in etti and claims that normalized tables of components are useless and nobody uses them. . .
You mean the autodesk? I think they did everything they could. This is where the situation is disastrous, out of control.
our dealer, excellent person, is exasperated by our continuous bargaining, retracting, threatening, not paying, rescheduling, taking half the minimum package or want the maximum package by paying a quarter.
He helped us, but eventually he got tired and you don't know how I understand it, besides some point, that of human respect, it's no longer worth it.
Autodesk's help if you can explain a problem to him, not if you miss your baptismal name, you lose a password every half day and you want a single account to manage the bolgia that we have and especially these things you're not behind and keep them in order.
