crash inspiegabile
  • Thread starter Thread starter m.mane
m.mane
I don't know what to do anymore. in a drawing file when I double clik on a note or quota to open the properties, the good pro/e closes inexplicably.
I tried to change the installation first and then reinstall everything but the problem does not solve, use the wildfire 3.0 m050.
Can anyone help me?
Do you happen on any design?
Have you tried to launch pro-e without configuration and do the same operation?
Have you tried to upgrade your pro-e? now there is wildfire 3.0 m200!
Let me know.
Bye.
I do it on any design and I have already reinstalled everything I can not update because my company for the moment decided not to stay in maintenance.
but now I have to understand where the error is in my configurations that I always use the same for years.
for the update I will try to see thanks.
I have removed all configurations and everything works I insert the configurations and returns the problem, I tried to use the configurations of my colleague (to him they work regularly) and on my pc give the problem. I tried to mix my config.pro and config.win with his but the result does not change.
now I will try in ptcsetup to vary the boot directory... . are well accepted other suggestions.
the problem then is in your configuration.
you have to do a series of tests: divide the config.pro into two and launch pro-e once with the first part and then with the second. verify with which of the two gives you the problem, so take the part of the config.pro that gives you the problem, divide it further into two and do the test again and so on until you isolate the option of the config that causes you crash.
I started doing some evidence, but the weird thing is that taking my partner's config.pro that works perfectly on my pc doesn't work.
for the moment any config I have uploaded has given me the problem, while I thank you and I will keep you informed
Can anyone help me?
m050? Rabbrividisco.... updated.
pro_font_dir c:\windows\fonts
Here's the infamous line of the config.pro that made me close everything.
I hope I have solved, even if I don't explain why since my config has been like this for years, I don't want it to have been some windows.
the update is scheduled for October directly with version 5.0 but I will insist on staying in maintenance.
hello and thank you all
windows fonts on old versions of pro-and gave some problems. you should set the font directory in the pro-and installation folder where there are only compatible characters.
Bye.
