crash revit
  • Thread starter Thread starter wikilivia
wikilivia
Good morning to all,
I press that I looked in the forum if there was already a discussion that answered my problem but I found nothing.
I have a problem with a revit file: when I launch the rendering, in some cases, the program suddenly closes without giving any notice.
I have already verified that the problem is only on that file, so I copied it all and pasted it on a new file, but the problem resumes. therefore the problem must be linked to some element I have in the construction.
Can you tell me if somewhere I can find error reports or how can I identify the "mother"?
or do you think the problem might be something else?
Good day
I don't know the program specifically, but some cads when crashing leave a log somewhere, very often you don't get a spider from the cmq hole.
try to hide/remove a part of the elements and make the rest, go for exclusion.
it will be an unorthodox method, but if the model is not overly complex, you put it there and you do it
:cool:with revit (all releases) happens if you use rpc's in the project that are failed. . .
eliminates all rpc's from the project (especially plants and flowers).
If you have to use them, you have to check one by one the rpc's and find the fouls.
but it is difficult work
or download mine (they are controlled and tested)
