creare 2d shape, command problem
  • Thread starter Thread starter pippo3194
pippo3194
I have to create the 2d of the detail that I created n shape design,
I try to go into the drafting environment, but as you can see, I can't enable the visual commands.Immagine.webpHow come? I don't understand what I'm wrong.
the file "paracorona.catshape" is saved in a format (.catshape) which is a format used in the environment product structure valid for representations.
I think that format is not recognized as usable for projections on drawing.. .
You will see that if you open any .catpart or catproduct file, the views commands are enabled.
