create 2 quick access bar
  • Thread starter Thread starter DANI-3D
DANI-3D
Bye-bye.
are struggling with the customization of the quick access bar, and I encounter a problem:
I have opened a solid part is in the bar I have inserted all the commands that I think are useful, but if I open a prt in sheet metal, a set or a drw the quick access bar will return the default.
Is there a way to make a single customization of the quick access bar that goes well for all environments? or do I have to customize one for one?
Hi, dani,
I made it separately for each environment (I mainly use 3: part, assembly and drawing), but it would not be bad to have it unique.
I believe, however, that in the latter case there would be problems with specific controls for individual environments, which in essence would not be loaded (at least I think).
Let's see if anyone enlightens us.
from the online guide:
to import custom settings saved in a .ui file, follow the steps below.
1. click import/export (import/export) ▶ import file customization (import customization file). Open dialog box is displayed.
2. select the appropriate file with .ui extension, and then click open (open). a customization message box is displayed (customizations).
3. to apply custom settings only to current mode, click import customization mode (import mode customizations). 4. to apply custom settings to all modes, click import all customizations (import all customizations). 5. click cancel (cancel) to cancel the import operation.
Maybe this could work out. . .
in particular I wanted to put those general commands that are good for all tastes, like:
set workbook, rename, turn off plans, axes etc.
opps, found :mad:
but when I go to the other environment and the reload does nothing, I will try again.
therefore import "to all modes" does not solve, sin.
As soon as I have some time, I'll try to find more!
Perhaps I mistake some passage, even if the operation is extremely simple, but to me it does not work:
in the usual environment I carry the settings in the .ui file, I go into the sheet environment, I reload the file, but nothing happens.
Now I tried, too, but it doesn't seem to work.
Obviously what I found in the guide is not exactly what you were looking for.
I'll try to find these days.
you tried to see if the variable (PHP 4 = 4.1.0) is set to yes (pay the default is no).
(I'm throwing you there, sorry)
