create 3 setting tolerance tables
  • Thread starter Thread starter faguide
faguide
I ask you if you can set default on the config.pro tolerance tables to use on the drawings.
more than a config configuration, it would be a start-part setting or anyway of the file (because it is assumed that each new object starts from pre-configured start-parts.
then on file - prepare - model property - feature geometry, find standard tolerances
