create a copy of a taskpane component
  • Thread starter Thread starter ChicoBambi
ChicoBambi
Hello, everyone.
first of all they are not very/ practical customizations.
I run a custom library of some parts I usually use.
dragging them into the axieme file if you change the starting file.
How can I make a copy of the file in the current directory?
first ctrl+c and then ctrl+v
no, I mean from taskpane or otherwise directly from solidworks
I have a set of libraries and should open too many folders
drag a file from a library present in the taskpane or toolbox into the graphic area of a set.
I wonder why I saw him do it to an external designer who uses solidworks
How would you make a copy by inserting it into a set? you are inserting a particular in a container
when you reconsider let him explain and then explain it to us
