create a cross-reference of attributes
  • Thread starter Thread starter studio tecnico riccardi
Hi, I need some information.
I better explain, I have to do that by changing the attributes of a block that I will call to change the attributes of the block b and if I change b, it will be modified as well.
Moreover, if I connect b a with a line or another block, in the attributes of the block b and a must appear to me
the name of the block c (e.g. joining him) is feasible?
How do you do that?
thanks in advance
...is it feasible?
How do you do that?
automatic is not possible, if you were a good programmer (lisp, vba or .net) you could create a routine that once launched verify the conditions and, if necessary, perform the appropriate changes.
oops, replicated "automatically" :biggrin: the intervention of tristan...
I think it's not my case, how can I learn these programming languages?
bhè, however, cross-references may be made without the lisp or other programming languages using data fields (object->bloc->attributed).... for the rest you said ... I confirm what is said by tristan and gp
