create a new cartilage
  • Thread starter Thread starter peppe068
peppe068
Gentlemen, I know I'm asking for a trivial thing, but I need to know how to operate on nx4, to create a new cartouche.
I mean, do I have to draw a line by line? or can it be imported from a dwg or dxf?
in every way, creating a new drafting, how should I proceed?
Thank you very much to all.
Since it is not a thing you do every day the advice is to draw it line by line,
You could import it from a dxf/dwg/cgm, but in the end you have to put it anyway.
It's worth it, especially if you want a compilation of the text from attributes, doing everything ex novo or using your base and editing it.
If you're looking in the old treads you'll surely find some material I had posted on the carts, I think there was also a bck plug that allowed a compilation
I'm sorry. I'm adding to the discussion. I am neophyte of nx7... I also have this problem with cartilage.. I want to import one that I already have.. I read a discussion that helped me import into drafting only patterns... My file to import is a model of nx7... Then I save it as a pattern... then I load it in the new file.. with the size the stairs I find myself in everything... But it comes out very clear when the pattern amounts... and on the press even more...if it is possible to import it from a dwg that is a file of autocad would be very comfortable but how to do?... where can I find this application you talk about? I'm sorry if I was prolisso... Nice to meet you.. Thank you in advance
