create a new plant level
  • Thread starter Thread starter 00zylit
00zylit
Hi, I've been using revit for a while now, but I've been tripping into a problem that never happened to me.
I have always created a new level of plant from a prospective view creating it from an existing one. My problem, however, is that I don't see the plant levels in the prospectuses (I don't know why) and so I can't create new level.
problem probably very trivial but that put me in trouble! !
check that the section pane is not active...in case you view it with the bottom left button in the view bar and disable it.
You mean the crop region? I tried whether it's active or not. I also tried to create a new prospect or a new section. Nothing.
you have not active "hidden by sight"-->category and therefore do not see the levels created?
is all visible, even if I put it displays hidden elements does not display anything
I miss something... but if you create a new level from the prospectus view without duplicating it from an existing one, what happens?
...with the appropriate command, I mean... what you see in prospective/section views
that displays it.. but the previous ones do not....
I just want to see that anyway. . It will look stupid but I never knew the existence of that command....I always used an old man to create a new one:smile: However if you think of a method to show the old ones let me know....while thank you very much!!
...do we not do first and better if from now on you use the new command just discovered? :wink:...
Please.
Bye.
