create a set with a parameter on a dynamic block
  • Thread starter Thread starter MikX
MikX
I'm trying to figure out how to make a series on a dynamic block. the series however must have an external parameter to the block to adjust the step of the series itself from time to time. a little as if you wanted to create a parametric comb with a parameter that defines the step between one set and the other. using this block I should be able to define the step without editing the block.
if you make a dynamic block the properties come externally through the properties of the block itself
if you use an autocad version after 2013 you could create a series (array)... command serierettangfrom that version the series are parameters and are created as blocks.
once selected by acting through the controls in the ribbon, change the spacing between the elements and their number (also via grip).
Would you be able to create a dynamic block with series and a grip that changes the step? I just can't. Thank you.
a dynamic block cannot do it... unless the distances are known and number finished, in this case with the visibility states would be resolved.
you could set a scalaxy parameter to change the distance, the problem is that then deform (long) the block even along the y.
In fact I should have a step and consequently a number of variable series elements.
Thank you so much was exactly what I was looking for.
Now I should understand how to apply a iron parameter to that element in series.
In the annex I put the dwg, the element that I would like to iron down is the one inclined to 45°. Thank you.
