create a square inside another square
  • Thread starter Thread starter brom
brom
Hello.
I have created a square of 600 (mm) on the side, now inside this quadatro I would like to have another, smaller, that is centered of 25 (mm) on the side. I tried to apply the horizontal and vertical parameters by applying them to the two squares but only one side is aligned and the square breaks (I tried to rasp the four sides with the group function, but it seems they are always considered as lines)
Can anyone help me?
use the offset command.
if they are lines you will have to select them one at a time and then cut the protrudings; if you create the square with a polylinea you will simply select a line and you will have the square already made.
