create a table by extracting attributes from blocks
  • Thread starter Thread starter Simone Micucci
Simone Micucci
Hello.
I am a new member, this is my first post. ^
It is a bit that I spray with the search function, but I can't find a thread that specifically treats my problem.
I'm using a mechanical autocad 2008. I have created a series of dynamic blocks with attributes inserted (the important attributes for each block are three).
I have no problem here.
when I go to do a data extraction to create a .xls document the document is created normally, the blocks that have the attributes with the same value are added correctly and formatting is the desired one.
I would like to be able to create a table directly within the .dwg where those blocks are inserted. problems begin here.
i go to say draw->tabella-> from data object in drawing (data extraction)-> create a new data extraction* ->ecc etc
*in this data extraction I follow the same procedures as the data extraction I use to create the .xls document and give me valid results.
at the end of the process I go to insert the table in the .dwg and the result is a disaster. some attributes are reported, others are not, some equal rows are added, others are inserted separately. I can't figure out where I'm wrong.
Has it happened before?
thanks in advance to those interested in the problem (and any excuses if it has already been treated)
