create abaco doors "personalized"
  • Thread starter Thread starter umbo1987
umbo1987
Hello everyone!! !
I have a question!!! how do I create a door abacus that takes into account the door opening hand,
Thank you very much
umberto
ok but among the voices "filtrators" I have no voice that refers to the opening verse.... thank you! ! !
I think that this is not possible however with the normal tools of revit. probably, you can find a tool of 'bees' in the internet to do this. But at the moment, there is no property in the families of the doors that can be used in the abacus to know the opening hands of the doors.
I meant that in the family you can remove the command of reversal of the sense of opening, then create two families of doors with only one sense of apertur (dx - sx), and use them according to need, in the project.
in the abacus, with filters, select and group according to the opening direction.
Oh, two families of doors, one with the door to the left, and the other with the door to the right? hmm...
exact, nested in a third in which, creating a shared parameter "family type", I choose the opening verse I need.
shared parameters are abacable so the game is made;).
What happens with this idea if someone uses the "flip" control to change the orientation of the door?
I disagree, no software is perfect and revit is no exception. the list of escamotages to be used to fold the software to their own needs is long, from filters for non-built and non-demotion, to the "mounting" of graphic abachi at the table etc.
In particular, I have a perfectly bim port where i (informations) is fully supported, simply to properly orientate it I change the value of a parameter instead of clicking on arrows. the door is editable,replaceable,contactable,updateable. therefore in what sense would not be a solution to revit?:confused::smile:
does not make a fold:smile:
@alfredo
not to discuss with spears on families, is a luminaire in the matter :tongue: :finger:
