create and represent a 4 inch cylindrical gas thread
  • Thread starter Thread starter liga76
thanks really to everyone, I used the table we already had in the company is an excel file.
I mean that in the .catpart document when creating the thread you need to navigate with the appropriate button to select the thread table
reading some messages (there is always to learn) I also saw your message where you say " gas also called whitworth. "
I must correct you (only for the taste of the discussion) as the gas thread is completely different from the whitworth thread.
I understand falonef.. Can you tell me where the .txt wire must be saved? I tried, but it gives me the mistake I posted. . .
...put the .txt file of threads in the folder that already contains the 2 files of metric threads in this directory:
....dassault systemes\bx\intel_a\reffiles\standard
we waved
I tried to insert the file "g_iso_228.txt" in the directory I previously indicated but an error is reported to me. I therefore attach the file I have used for years and that has never given me problems. In this way I open the table directly from the cell where the 2 tables of metric threads are already proposed.
we waved
Thanks mocca.. I did exactly as you say.. I put the txt file on the folder where there are files for metrics... but it gives me the same mistake... probably the file is not appropriate.. I'll put it... Maybe if you could pass me a suitable one, I'd really appreciate it. thanks also to you falonef.. .
You're amazing. you have preceded me... really great....:-) thank you very much.. I'll try it right now. .
hi liga, I use in the company this table uni iso 228 that I was very useful, I hope it will be useful also to tea. read it and below there is also designation.
a council always refers to the norms that are references for all companies.
a small clarification:
we usually use the .xls tables, we must respect the number of columns and the denominations.
