create continuous façade system from walls!
  • Thread starter Thread starter 00zylit
00zylit
I have to place a tile coating on a building. to avoid resorting to extrusions or continuous facades where I should cut out every single window, I would like to use the façade system continues only that revit, for what I know, creates continuous facade systems only by masses, in fact on walls created as generic models works perfectly!
Does anyone know how to get around the problem? maybe even creating a generic mass from a wall and then creating the facade continues from the mass!
Thank you!
... sorry, but I have not understood your problem well: if you can attach a pattern/draft...
Cad3D.webpThis is the structure I should cover. coating is the same for covers and facades. roofs are made with generic models, while walls are the classic generic walls. Therefore for roofs it makes me select the surfaces and create the facade continues while for the walls I have to manually create a continuous facade from which to cut out the windows and make adjustments. nothing that cannot be done, but I wanted to look for a cleaner solution if it exists, so as to select all surfaces at once and obtain a single continuous façade system.
Thank you!
the selection of all surfaces, no; but as you say with the selection of : walls>continuous, and using (in primitive) the line selector (arrow symbol with line) highlights the path (line) of the existing walls, and with a "continuous" selection do all the fc.
always as affirms, the facades should be adjusted (and the windows inserted), but at least the above selection correctly inserts the pillars on the edges (changes of direction) of the fc
I apologize for the delay of my answer but I had problems with the connection. . .
I wanted to thank @gfrank for the answers received!
