create elements pro, relationship together:
  • Thread starter Thread starter giuglioconiglio
giuglioconiglio
hi I create elements pro 1.0 without advanced assembly and I would like to know if I can create a parameter in a set, which is a compound of carpentry, and "read it" in the subparts so that by changing only that parameter the subparts automatically change me. In practice it is the length of a carpentry arm that I would like to manage from one point instead of having to continuously change all subparts. is it possible without advanced assembly? If so, how?
thanks matteo
you can do:
open the set and go into the reports, in the search box in, select part, and click on the detail that interests you, you will appear the relationships of the part, at this point go into the insert > from list, select the code of the set, select the parameter that interests you, insert selections, so doing in the particular you find the value of the parameter created in the set.
I hope I've been clear.
ps these indications go well for wf5 I do not know if with creo there may be differences
