create half-car axes
  • Thread starter Thread starter D4n13l
D4n13l
hi to all I am using creo 4.0 m080 from about three weeks, I have always used inventor, and I am finding many difficulties to use creo.
I have a problem I can't solve and I hope you can help me.
I managed to visualize the axes of the holes "by displaying model annotations" but I can't figure out how to display the axes of the component on the table
Can you help me?
Thank you very much
you can create halfway axes in the 3d (passing for halfway plans) and then view them, as you did for holes axes.
sent by my sm-g950f using tapatalk
half-car axes if not created in the 3d model cannot be seen with the "show model annotations" function. by created I mean or made as datum axis or automatically with features extrude or revolve.
great I did as you told me but there is another method faster by chance?
Thank you very much
no, there is no faster method, for holes and series are generated, but for the half-work of the entire component (except for revolution) the only one is to create the plans.
I think the answers given are not quite centered. the problem is not clear.
It is not logical to create axes in the 3d for having them in the table.d4n13l Can you post an example?
starting from the concept that each feature of circular or cylindrical geometry (extrude/revolve) is associated with an automatic axis that can be shown quietly on the table with model annotation display. then if it is neecsary to create this axis in model 3d to take it back into the table, I would say that I create is put wrong.
a half-axis of a component, may not coincide with a hole or cylindrical surface or similar, so to create an axis that, parameterized, acts as a half-axis, is more than lawful.
wrong to me instead to draw in table 2d any axis or reference of quotation, geometric tolerance or equivalent, that if the geometry on which it is built is fail, can jump without giving any signal.
