create mirrored copy
  • Thread starter Thread starter lollone
Did it work like that in the wf3?
I explain, where I work we use the mirrors, with 2001 we had a very fast technique that used the surfaces. then in the wf2 they changed the mirroring surfaces, for us big damage. from the wf3 there is the mirror part, but I didn't seem to have the automatic copy of the drawing worked.
We only use wf4 for 2 months.
confirmation
it worked so also in the 3. if I think about the time we lost in acrobatics with intralink... I don't know what to think.
for the fact that in the mirrored copy disappears the flat and therefore all the views with the quotas referred to it. Is there a solution for this?
I'm checking but it doesn't seem to manage the family table (the flat state).
In fact the particular in family table is as if it was another design although dependent on the generic.
In fact it is a problem that I hope will solve as soon as possible, that of the un copied variant.
If you have details in the family table of sheet metal and want also the variants of the flat state, you can bypass the problem by putting in the family table the flattening (not the flat series).
Sorry I didn't understand.
in family table there is flatness and not the flat series... should I also copy the family table variant with the mirror?
Hello.
I resume the discussion for a deepening; If the mirror is made of a set, for example a welded frame and then worked, of which of course before I made the table, is it possible to obtain the mirrored copy of the drw?
Hello.
hit in the sign!!! I'm also asking myself, I have a complex set generated with the create-new-subassieme-specchio command and I just can't bear the idea of having to remake the drw too. It would be cool if you could use the model replacement command in the drw a mo of instance of family table. but I think here is another story unfortunately
In this case I would not lose any more time I take the initial design add note n. 1 pz. dx + 1 pz. sn or other similar. to the maximum export in dwg and use the mirror command of the entire design (obviously with the option quotas and notes on no)
aminati
