If I create a block then I open it in place, but I also want to create a block in turn without having to go up and then create the block that I need out. there is a method or autocad is so limited! ! !
the correct procedure is a bit different but still valid, i.e. you create the two blocks in a separate way, then edit the upper one with "local reference change" and add the second level one. save and leave
Yes thanks I knew already I was wondering if you could do it quickly as I said , for example me10 fà.peccato, but there is no utility for the blocks that handles them better? ?
