create new tangent line command
  • Thread starter Thread starter boyluke
boyluke
Hello.
as from title they are to demand the vs help for creating an unknown command to autocad.
the command to create consists of a line that starts tangent to a radius to which I can give length and angle of inclination...it is a very used command in the previous cad thinkdesign and now that we have passed to autocad we are without it..for now we use filling solutions that make it waste a lot of time!
Thank you for your help! ! !
Does anyone have an idea?
practically must become as the command line of tangent constructions. I want one to create a single line and not a construction.
I also come from thinkdesign and that command was very convenient. in autocad and machanical does not exist:(. we solved using the command "line", then activating snap tangent positions you on a dial so take the point on the axis as reference then make the line with the length and angle you want. I hope I made it clear... I did it once.
I hope I understand your request well, I wrote the attached tc command.
upload it with appload.
requires:
- circle selection (or arch)
- length line
- angle of perpendicular to the tangent
inputs can be entered by keyboard or graphic input.
to reverse line direction: click left or send to accept that proposal.
I extracted the zip and tried to load the command as from instructions but it does not work me. I must first insert the .fas file into some particular folder where then the appload command will go fishing?
But I have to say that I am better with this macro:
_
if it can be useful to others...I did nothing but merge and automate various autocad mechanical commands.. .the result is appreciable even if it is not at thinkdesign levels.
