create normal screen plan (in view and/or video)
  • Thread starter Thread starter heterodyne
heterodyne
Hello everyone,
someone of you knows how to create a plan in create parametric that is normal on the screen.
to simplify, create a plan compared to the active 3d view, which is normal then to the video.
in sw, for example, you can define a plan of this type through the active 3d view and a point, which will be the origin of the plan itself.
thanks in advance
in creo you have to make a coordinate system that is oriented like the view (I don't remember the exact wording) and then on this you can make us an orthogonal plan to one of the axes (x, y or z).
Bye.
in view management you can create a screen view as you like and save it.
with dynamic orientation you roar as much as you want.
you will find it among the available views and when you select the piece will reorient.
also when you make the table you will find it among the views already ready type front,top,etc
try this solution too, hello
Thank you all. I ask you one more thing (without opening a new post). know if there is a method in isdx/style to edit a surface by moving/scalating points/cv symmetrically to a plane. I saw there are several options to move cv's compared to normal but nothing I found to scale them symmetrically
