Garrett
it's been very short that I started using solidworks for hobbistic purposes only, at the present time I managed to draw parts using extrusion functions starting from 2d masks imported from autocad (with which I the cavity quite well)
subsequently the various parts assemble them in a set through the mating functions.
the problem is that now I need to create a part, to add to this set, that for how it is made it needs to be created on the basis of the latter. Is it possible to do that?
in particular I would need to do this:
This is as far as I arrived, as you can see, all parts can be obtained very banally by extrusion. I would like to add the two conical lids, these:
and, definitely easier to do, add the two rods that come out from it:
my question is precisely if it is possible to do so starting from that axieme depicted in the first image, to make the tubes for example I thought to make a circle exploiting the appropriate axis as a center and then extrude it, but I did not even manage to make appear a miserable axis on which to support me. . .
I thank anyone who has the patience and time to lose with a newbie like me.
Andrea
Andrea
