DeDios
Good morning to all,
I tell you briefly my problem: I must return the relief of a farm of 1700. the problem is as follows: being the walls made with the stone, and without any bubble, in the plant the outer and internal threads are not parallel, so the wall is not constant. Is there a way to make walls with non-parallel wires? if there is need for clarification I can post a small shot of the plant made in autocad.
Is there a way to realize the doors and windows with the "boxes" at the top? I'll explain better: the windows are "crazy" in the wall, and the top end with a curved area. in case even here place some photos to clarify better.
thanks in advance, good day:wink:
