create spring with if v16
  • Thread starter Thread starter mauretto81
mauretto81
Hello, friends. Luckily, if he turns me on the laptop and then I started modeling for the exam... Now I am in front of a rock.... I have to model a grinding wheel with if ....cono sco the free length, the diameter of the wire the diameter of the spring. I tried (as will the prof. ) with the helical protrusion command but I can't... How can I do that? ? ?
hi, then here on the forum most users use the latest solid edge releases, so even if we send you sample files you will not be able to open them.
if you open the online guide and write "helical protrusion" you will open the example page where it is described step by step how to create the spring.
I'll attach your image
Thank you very much. .
Now I look at the guide. Unfortunately I have seen that the files created with if commercial version cannot be opened with the academic version of if that gave us the prof.... I try to make a spring I ask: . .
Ps: Kill... beautiful black kitten you have as avatar.. .
Yes I have forgotten that the commercial and academic version is not compatible, however if you need ask
off topic: black kitten is actually a cat (female, 1 year in June) and it is my miciooo and it is called blackie roses
