create subaximes with simplified representations
  • Thread starter Thread starter Rael84
Rael84
I would need to disassemble my .asm in other subassies, i.e. enclose groups of .prts of my main set in other subassies. I had thought of creating a simplified representation, containing only the .prts that go to form every single subaxieme, save the subaxieme so created and then eventually re-assemble all subaxiemi to recreate the main .asm. Is that a good idea? or are there more comfortable ways? thanks to all
you can use the renovate command within the edit menu. first, however, you have to create the empty subaxis within the main axieme.
select the component to move and the axieme where to move it.
Great, it works. . .but you can't select more .prt together, but move at a time, can you?
