create vased walls or variable thickness.
  • Thread starter Thread starter gDel
gDel
Hello everyone!
I have a problem with the construction of walls vased, or with variable thickness; exist types of walls with these characteristics? Is it possible to create them?
You have to create them.
component> local model. assign a name to the wall draw the profile and extrude it.
You may need to join more walls.
change>unisci geometry.
thanks lance, however I found a faster way; I created a solid with the features I needed and with the command <crea da="" di="" elemento="" solido="" superficie="" un="">, it creates it automatically and recognizes it as a wall made with the traditional method.
Bye!</crea>
a question, did you create it as a mass? If yes, when using the command creates a surface element should not have created a wall for every face of the solid you designed?
Yes the solid I created it as a mass.
the command allows you to select only one face of the mass and extrudes the wall inside the volume, placing it exactly as the mass volume!
Bye!
Sorry gdel, but the wall once inserted on a surface of the mass does not take the shape of the mass but always remains a straight wall that I know...insomma certainly does not come out a wall of variable thickness in the plant! :confused:
Hello everyone, I have problems in building a castle especially with the final walls since they are oblique walls and I can not give it the right rotation in some view I am.... Who can help me? ?
Thank you in advance for your collaboration! !
question put too vaguely... give us some extra information, attach also images, otherwise I see hard
1.webpI have this cloud of points, I have to make side walls as you see in the photo and sincerely I do not know how to move
you don't understand much from the image, especially the thickness of the walls. However to feeling I would use base walls and wall extrusions for bastions
yes even the bastions were a great problem, I would also want to understand how to tilt the wall to sketchup ways
have you read all this from the beginning? there are solutions in the beginning. Look at the messenger # 2. There's not much more to do.
