created line in 3 sites
  • Thread starter Thread starter belcarlo
belcarlo
Sorry if I ask a trivial question, but you are all very experienced, I am trying to use and learn inventor alone, with the only help I find on the net.
I have this problem: I have to create an unrighteous line, which is not on two dimensions, but on three. ie start from a level of +10cm and making a semicircle of 210 degrees must arrive to 0 cm
I think I understand I have to use the 3d schozzo but I can't.
Is there anyone who can help me?
carlo b.
I don't know if it calls, but I have to create a path and then create a downhill ramp as I said from 10 cm up to 0.
I'm sure it's as you say
How do I behave?
created a 2d sketch of a line that will represent the axis of the helicoid and exit from the sketch.
After creating a 3d sketch, you have to press on the arrow of the sketch button and choose 3d sketch.
once in the 3d sketch choose helicoid fixes the point of origin to the origin of line 2d and the end.
after from the window of the helid manage the various parameters.
I hope to have been clear it is not easy to describe in words but it is practically not difficult when understood the mechanism.
