creates...
  • Thread starter Thread starter Mat76
Mat76
Good morning to you.
Now in all modeling software there is a command "create/drawn as", selecting the element proposes to recreate another of equal properties (color, line, style...).
for autocad exists a command or similar lisp?
only after ten years known that I repeat the tracking of the lines and I apply the copy property when I could think of one command.
There's no such command in autocad.
You must be:
or more organized (draw an object and put it on its layer that has certain characteristics such as color-thline-style etc);
or more disciplined (color-thline-style holes before creating entities and designs so until the next change).
but do you mean to recreate a whole design or just the single element?
because for the individual element the command exists.
you just have to select an item and use the command: add selection (addselected) from the context menu.
I find it particularly convenient when I have to add some quotas even if it seems to me that in the case of the annotative quotas you still have to select the correct insertion scale.
instead to recreate entire designs is perhaps the case of using, for example, dynamic blocks or however parameterizing the design.
There is also the possibility to record their actions but I do not know how useful it can be.
