creating compost iproperties
  • Thread starter Thread starter and
and
is it possible to create an iproperties as a union of two iproperties?
example :
create a new "variable" that calls "translation" so composed:
translations = French + German
in my example :
translation = vis tête ronde bombe bohrschrauben
Okay... now it works...
and if you want to transform this solution into a string for an external ilogic rule?
I created an external ilogic rule to calculate these attributes... but in case there is no value it blocks me the continuation of the rule.... How can I overcome and tell him if he doesn't find him not to make a mistake and continue?
iproperties.value("custom", "desc.en") = iproperties.value("custom", "English").tostring
iproperties.value("custom", "desc.f") = iproperties.value("custom", "French").tostring
iproperties.value("custom", "desc.d") = iproperties.value("custom", "German").tostring
with this ilogic if there is no "French" value blocks me the ilogic and the "desc.d" does not value me!
can insert rows into a try/catch/end try or add an on error resume next : the two options cannot coexist
Code:
'gestione errori completa
try
    messagebox.show(iproperties.value("custom", "propertyname"))
catch
    'in caso di errore
    messagebox.show("manca")
end try
' gestione errori grossolana
