Iraz
Good morning to all,
actively return to this forum after years of inuse.
already, because I returned after years of fasting to design with the 3d.
today I find myself to remain the software (I like it) but for different purposes (I was passed by "simple" sheets for photovoltaic structures to sheet for electronic components).
My problem is as follows: I am creating library functions so as to speed up work but I can't create them properly. In particular I am trying to build a function to create cooling fins for air passage.
I know that there is already a default function, but my garments do not like and want to create the fins not with the mold, but cutting and bending (I attach image).
the function however is created by extruded cut, then tilted plane and extrusion from this plane itself. I don't like it because it doesn't allow me to do the "distendi lamiere" for development.
I then went to make on lamiero a sketch to perform the cut, then flange edge, then cut (to give the desired shape) and tab (always to reach the desired shape).
here is where the problem arises; I want to save the library function but do not "accept" the flange edge, as if the software did not understand the reference of the flange edge function.
Could someone from the forum give me advice on how I could proceed?
I use swx 2016
good day and good work at all
I use swx 2016
