Ing_G_A
I'm learning myself. .
You have to use the datum plane. and immediately after you use it for the sketch.Good morning to all...I contact you to kindly ask you an information about the views of the design that creates the program when I step in drawing mode...especially in addition to the views on the plans: top,front and right....how can I do to get the view on a plan I defined?
Thank you very much to all.. .
ps:I defined the plan in part mode, then in drawing mode I did right-click: add auxiliary view; but nothing happens. . .
dubito can be developed in sheet metal environment.Hello everyone, I contact you because I'm finding it difficult to spy on this surface obtained with a set of limit blend that I then joined and finally used the often command to then switch to the functions of the sheet metal... I attach the file of the pro and in addition I attach the photo of the piece that I can't spy on... is the component prt0005... I hope you can help me! thank's :smile:
