creation and cancellation
  • Thread starter Thread starter yag
yag
Hello
Therefore via code creates a menu with the classic commands that the vba of autocad provides also present as an example in the help.
at every start of my application I make a loop on the menu items
in group zero gates and add type appl_1.0.00 the first time all
works well at the next reboot (of my appliccation) because being
previously deleted does not add it as long as you do not restart autocad
do you have any advice on this to avoid this torture :-) ?
Hello
you cannot post an examplep
or the code that would be even better?
There he is.
Code:
dim gb_numeroblocchitrovati as integer
set gb_versioni = new collection
gb_versioni.add "aaa- start-"
gb_versioni.add "aaa- 1.0.0.0"
gb_versioni.add "aaa- 1.0.0.1"
dim tmpfieldname as string
dim currmenugroup as acadmenugroup
set currmenugroup = thisdrawing.application.menugroups.item(0)
for i = 0 to currmenugroup.menus.count
        if i < currmenugroup.menus.count then
            if currmenugroup.menus(i).name <> gb_versioni(gb_versioni.count) then
                currmenugroup.menus.removemenufrommenubar (currmenugroup.menus(i).name)
            end if
        end if
next
err:
'msgbox err.description
gb_versionecorrente = gb_versioni(gb_versioni.count)
