pagnotz
if you have to create a very similar set to one that you have already created with one of the generators under "design", type "frame", "shaft", "engineering", and you want to exploit the existing one creating a copy to change without losing the original, how do you do?
It is not so trivial as a question because the components created so they always have a structure together-parts, even if it is a simple tree, bound together and the design functions accelerator.
If you do, for example, copy of an abc.iam tree containing abc.ipt, I can use "save and replace component" to rename the axieme in abc2.iam, but it does not allow me to do so of the ipt, as if it were "protected". in the case of a frame is even more complex the matter, it must somehow rename the axieme, the skeleton and the components... what method do you adopt?
