creation exploded on creo
  • Thread starter Thread starter light incautious
light incautious
Hello!
I would like to know if someone can recommend me a good tutorial to learn how to use creo for explosive creations. in particular my problem is as follows:
I have a ready set on pro engineer that I should create the explosion on creo. how to make the exploded I understand, the problem is that I create the automatic explosion, I also saw how to manually move the pieces once I made the automatic explosion but I remain the problem of how to move a tot of components from the main axieme all together (I explain better, I have to create the main table where the axieme is divided into 5-6 main subaxes then from these to scale more.
I found this tutorial but unfortunately I was not very helpful http://learningexchange.ptc.com/tutorial/670/aggiunta-di-viste-esplose-di-un-assieme
Bye!
Have you tried to search on the forum? There should be some discussion about explosives... .
I use wf3 but I doubt that I create only the automatic explosive (from an eye to the first image I attach you, should not disconnect much from creo).
In general, I prefer to start from scratch creating a new explosion, and egg, components (even more than one, see second image) and sub-assiem to my liking.
I may have misunderstood (in case, excuse me and explain me better) but for the explosions of the subaxiemi, I think it is more correct to make dedicated drawings.
ps: try to cuff us first person, even without tutorials, I do so and I did not take long to understand the "his" way of working.... :smile:
why do not try to activate in a more complex set than that posted and activate the default explosive
http://www.youtube.com/watch?v=xabambudo8k&feature=youtu.be
hello dema, unfortunately I have youtube blocked, and so I can't see your video.
I tried sometimes, with assemblies of 500-600 components and I'm not well, not even thinking about it for bigger assemblies, but with this I don't want to say that they don't work, maybe I'm wrong to realize the assemblies.
Can you use it?
....the problem is that I create the automatic explosion, I also saw how to manually move the pieces once the automatic explosive is done but I remain the problem of how to move a tot of components from the main axieme all together...... .
........dubito che creo do solo l'exploso automatica (from an eye to the first image I attach you, should not differ much from creo)......
no automatic explosive is unusable.
That's why I invited light incautious to look at my example, where I can see that I used the explosive manual. on the fact that you do not differ much from I create, it is my assumption on the procedure to be followed, not on the effectiveness. I hope they have improved some things: within a few months we should land on creo 2.0... let's see. Bye!
