creation maintenance documentation
  • Thread starter Thread starter biXel
biXel
Good to all.
I was lurking the web and I noticed that the ptc application I create illustrator seems to be very pushed on the side creating technical documentation of machines.
https://www.ptc.com/products/creo-illustrate-tour/in nx, as far as the animations are concerned, I think there is only the 'sequencing', but tools capable of doing what I see in the videos on youtube on creo illustrator, I think there are.. .
Can someone give me some info about it?
nx integrates such interesting tools as illustrator?
Thank you very much.
Does anyone know anything? companies that use nx and must also develop technical documentation (assembly manual, or for spare parts) rely on third-party solutions?
sent by my col-l29 using tapatalk
we do not use nx for technical documentation. I found this interesting:
It's not what I meant.
the use of pmi is one thing, having a package that deals expressly with document creation from the data cad of a set, for example, is much more.
in fact ptc creo has that ''packet' voted precisely to the creation and management of documentation post production/assembly ( both animated and 2d classic ).
something like that seems to me to be short 3d, found by spraying the web.
Thanks equally:)
Good to all.
The match for siemens is called short 3d.http://www.cortona3d.com/en/partners/siemens-plm-portal
a package that is evolving (also) in that direction is nx/animation designer.
otherwise, short
They're all right. However, there is no association between data cad and animated documentation. designer is nx and short animation is associative.
It's not true
ciao @+forte but that is associative between 2 applcations of the same suite. I don't know if coreldraw maintains data link between a cad of the mainstream ones (nx, catia, etc) and coreldraw. I don't think
You didn't read the pages I linked to you
and also the video,somma,you were not careful:)
per minute 0:47 it is seen that reopens a solidworks assembly, they could also use creo catia nx inventor, which now has two holes per side replacing automatically in the doc the part that had three holes per side
in the pages I linked you there is the reference to an additional component
to buy more,not part of coreldraw technical suite series
that supports all major file types of major cads
and that communicates and finds,when there is, an updated filehttps://www.coreldraw.com/it/product/technical-suite/xvl-studio/
I tried to see what kind of cad was opening and I missed solidworks.
Well, I'd say good then. Good alternative.
chorel seems more voted to mere 'classic' documentation (no animations, augmented reality.. ).
I'll be better documented on this suite.
Thank you very much for indicating:)
Good to all.
I know that short is suitable, I saw it at a presentation
