creation of a form for compiling revisions in a paper mill
  • Thread starter Thread starter sbronzo79
sbronzo79
I am trying to create a form that will allow me to fill out the revisions within the paper mill.
I press that to the various components of the revision I created a custom property.
how do I now tell him through vb to write in that determined property what I write inside the text box of if
is not in itself; I think it intends to make a program with visual basic with graphical interface. the "pages" of the program are called form. and the boxes where you write are called text box.
you must connect to the property object of the model, search for the group "custom" and then the custom property created.
Code:
set objpar = objapp.activedocument
set objprops = objpar.properties.item("custom")
objprops.item("nome proprieta pers").value = textbox1.text
to adapt to your needs of course.
sub addfileprop(file, name, value, optional tab = "custom")
dim objprops as object
dim objprop as object
set objprops = createobject("solidedge.fileproperties")
call objprops.open(file)
set objprop = objprops(schedule)
call objprop.add(name, value)
call objprops.save
set objprops = nothing
set objprop = nothing
end
by gianluca vespignani
I also made a macro that reads from the db and reloads the properties. we have a pdm but I had to update/add on file vidimati descriptions in English that in turn I had imported from the corporate management
call objprops.save
end
is a sub routine that you can recall to add/overwrite a filepropriety on any type of solidedge file:
call addfileprop("c:\prova.par", "mypropriety", "my value")
The code seems pretty simple
