creation of folded cylinder sheets with open rectangular head
  • Thread starter Thread starter Nicola Fantini
Nicola Fantini
Hello everyone, I thank you early for creating and supporting this powerful object forum to confront and solve problems.
I am new to the plate functions and I am trying to redesign through the use you sw a complex mold for the creation of a rod that will act as a handle.
from my knowledge of sw I know that first you have to create the particular that you want to realize so they are struggling with this object.
Now my problem is that I can't create a joint between the cylindrical piece and the rectangular one.
I attach the photo of the joint that I would like to get and the point to which I arrived.
Thank you for your help.
that joint you can get it with a loft, but from the photo you can see that it is not obtained by bending but by molding. the sheet module does not allow to develop deformed sheets for molding but only for bending.
probably needs a logopress type module.; I pass the word to oldwarper, who uses it...
thanks marcof for the straight, today I have informed myself for the logopress module that is great for the work I have to do today and in the future.
I also tried to get the particular with the loft and the particular with the right approximations turned out right.
Thank you very much for the suggestion.
