creation single parts in step from structures in structural elements
  • Thread starter Thread starter saturno979
saturno979
Good morning to all
I ask you if you have ever had to save all the parts that make up a structure designed with structural elements in step to send them to the cutting machine.... .
so far after drawing everything, hid the components and one at a time saved it in step.....
question: "Can I do it automatically with solidworks? all at once? "
Ing. a. salzano
apart that you do not need to do this because you just select a body from the distinct cut and do insert into the new part, unless there is a macro made on purpose you can not automatically extrapolate the steps or at least no it is possible to save it as a step creating a file for body.
what you can do is right button on the separate cut and save bodies; you are created a set with all bodies as a side file. to that qunto save as step.
separate cutting and saving bodies; you are created a set with all bodies as a side file. to that qunto save as step.
Thank you
I had never noticed save the bodies from the separate cut..... (y)
